I tried searching this topic but couldn't find anything on it.
I remember reading a while ago, that someone's cruise control stopped working after the installation of his turbo kit. Is that a normal thing that should be expected when installing a turbo is was it just that one person's luck?
Well, if there's no issue now then there should be a fix. I keep hearing Juan saying there is one but I never got it, or seen it in any thread. Never had CC since the day I installed the kit! So... anyone know what the fix is?
[quote author=Xenon929 link=topic=72646.msg1295873#msg1295873 date=1175053411]
^^^It's not on there. i never put it on after I switched my 2nd tranny.
Well, if the switch is in good working position, the CC must work properly. Mine is working perfectly.
ya mine still works...but i havent tapped much..my haltech is running off the follwing wiring changes only!
map sensor
fuel injector harness
12v memory from rear ecu
air temp
coolent temp
tach driver
i am not running the tps so i dont know if that will help with driveability...i didnt see anything saying to do anything with the neutral safety switchc...
im struggling only with my turbo timer i can't figure out which wires to tap in the steering column to get constant 12v, ignition, and acc. If you can answer this ASAP that would be awesome b/c I have to drop my car off at NOPI shortly. Also where is the speed sensor wire to for the turbo timer install. Thanks!!!
these are the color wires coming off my key input thing...haha technical term...this is in the steering column
Grey w/ orange stripe
White w/ green stripe
Black w/ yellow stripe
Green w/ red stripe
[quote author=eurotuner link=topic=74568.msg1331565#msg1331565 date=1176415579]
[quote author=Fox Fader link=topic=74568.msg1331534#msg1331534 date=1176414815]
now my car's going to get miled up.
ahah so what u gonna do 15 miles instead of 10 now per week!
I've had my car for 111 weeks and have put 9100 miles on it, that equates to 81.98 miles per week or approx. 4550 per year, so I will probably bump it up to 83.05 per week. Thank you very much Euro!!!!!
[quote author=Fox Fader link=topic=74568.msg1331623#msg1331623 date=1176417102]
haha yeah i made the maths too but i had u for 128 weeks!
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Mazda3 Forums
