ONLY ASKING 10,000 O.B.O!!!!
THERE IS FAR MORE MONEY THAN THAT IN THE ENGINE ALONE!!!
Ok, so i have run out of time for this car. It has been my baby, my pride and joy and my project for the past four years, but its time for me to focus on school... The car has 35,000 miles on it and is in nearly perfect condition. I take more pride in this car than most other things in my life, so the car always stays clean and all of the work that was done on it i did my self and i always make sure to to grade A work to the extent of torquing every nut and bolt to the exact specification as specified in the mazda manual. The car runs hard and strong at 15 lbs of boost, but does have a smoking problem. I have not been able to figure out why it smokes (although at this point i think the rings are gone since i have literally changed EVERYTHING else that could cause a smoking problem including rebuilding the turbo). The car is scary fast. Good luck getting traction at under 60 mph. Here are some of the most recent pictures that i have taken of the car and a full modification list under the pictures.
Stock Features
-Black paint
-5 speed
-S Package
-Rear wing
-Red and black interior
-6 speaker sound system
-6 CD changer
-Sun roof
Here are the aftermarket mods I have added:
Performance
-HiBoost Turbo Kit
-Borg Warner 54 Trim T3/T4 Turbo
-Wiseco pistons (8.8:1)
-Eagle Rods
-Exedy Stage 1 clutch and pressure plate
-PCS Xtended Fuel Controler
-Walboro 250 lb fuel pump
-TurboSmart Vee Port BOV
-Tial 40mm Wastegate
-480cc Injectors
-Catch Can
-EBC Red Brake Pads
-Skunk2 lowering springs
-TWM Short Shifter
-TruBendz 3" exhaust
-Engine Damper
-Lower Engine Mount Insert
-Bypassed throttle body coolant
-HKS Type 0 turbo timer
Exterior
-18X8 Konig Runaways in Shadow Black
-Nitto Nt 555 Tires
-Red ceramic brake caliper paint
-Carbon Fiber Eyelids
-LED Eyelids
-Erebuni fiberglass grill painted body color with red mesh
-Custom red mesh lower grill
-Bosch Wiper blades
-Red pinstripes that go all the way around the back of the car
-Removed door mouldings
-Shark fin antenna
-Tinted Tails and Badges
-New horn (sounds WAY better than the gay stock horn)
Interior
-Custom painted interior
-Custom center dash gauge pod (AEM Boost, AEM Oil Pressure, AEM UEGO)
-Digital tach w/ LED shift warning
-2 12" Sony subs in custom built fiberglass enclosure
-Kenwood 1200 watt amp
-Red dash kit from Mazda
-Premium red and black floor mats
-Red anodized pedals w/ CF inserts
-Red neon's under the dash (drivers and passenger side)
-Red neon's under the front seats to light up back seats
-Red LED to replace the trunk light
-Red LEDs to replace all interior dome lights
-Door sills that light up and say Mazda 3 in red
I'm sure that there is a ton of stuff that i am forgetting... Please contact me by PM or by phone (706-414-5579) if you are interested.
NO REASONABLE OFFER WILL BE TURNED DOWN!!!!
