1 - 3 of 3 Posts
so i have a focus engine along with my engine that I am rebuilding, I took my crank pulley off with a breaker bar when the motor was still in the car the focus engine is bare out of the car with no flywheel and the pin slot on the front cover is broken, how do you suggest i remove the bolt?
ummm...
Not sure what the call them but its a rod with a rubber belt that acts as a big oversized wrench.
do you not have any holes in this or bolts sticking out?
i came up with an awesome way, fabricated my own tool, drilled two holes in steel flatstock and bolted the flywheel side of the crank to the block, then used a 24'' breaker bar and it came right off, my little hole on the timing cover broke when i tried using an impact and punch
1 - 3 of 3 Posts
