[quote author=animosity link=topic=136361.msg2950456#msg2950456 date=1235161843]
I was planning on doing some internal work before I ran 14lbs, i'm just saying my goal is atleast that, I know whats going to happen if i run 14lbs.
I was planning on forged, and i was going to bore out my engine, maybe a mani.. and new spark plugs, camshaft... idk I'm just going to keep rambling on about what I want to do to it, got to earn the money first, and it has to get out the body shop first as well... wrecked at 120, but now it's completely rebuilt.
A: Dont bore out your motor unless it is absolutely needed, it will weaken the sleeves and possibly warp your cylinder walls down the road. You will gain noting from this since you can only bore out a few MMs
B: Manifold COSWORTH or CUSTOM I am taking my manifold into a shop soon to see if they can make me a custom one for an affordable price. IF they can and you can send me cash I will have them make 2. Not doing a GB Dont want to deal with that shit.
C
lugs are fine they are Iridium from the factory, go a step colder if you turbo
D:Cams good luck! Nobody makes them unless you swap a focus non vvt head, timing chain and crank timing gear over, then go with a standalone, then you can have cams. OR SPEND THE SAME $$$ FOR CUSTOM GRINDS theres a place by me that makes custom cams.
E: You are retarted and should not turbo. Main reason being... Good drivers know their limits and know when to slow down speed up etc, If you crash going 120 you either need glasses or your license revoked, dont be stupid respect other drivers on the road and if you do race try to do it in a controlled place where there are no other cars or pedestrians
Not bashing on you just some constructive criticism, every one on here gets it so get used to it. Im helping you out.
PS I highly reccomend you take a defensive driving course they are fun and will lower your insurance. They also teach you how to control your car at low and high speeds along with swerving out of a path of an object while staying in contol and etc (plus slalom and skidpad!)
