[quote author=Philly link=topic=65847.msg1129508#msg1129508 date=1167768839]
$1000 bucks to install cams, Your nuts ! Its really not hard to do on your own Since the cams are right under the valve cover. Sure the whole turbo thing sounds nice but there is a lot more to adding a turbo then just slapping it in. At the very least you have to do your fuel system too. If you dont by forcing more air into the motor you cause the air to fuel mixture to lean out. Know what happens if it leans out too far. Kaboom. Now you need a new motor. Not to mention our manifolds are plastic. Not sure how the boost will effect that. Guess it depends on how much boost your going for. Then there is also the head gaskit. Ya I can keep going on and on. Im no Import super mechanic and most of what I know is based on domestic V8's but im sure some of the same principals apply.
Im not going for an all out build. Just looking for a little extra power, but like the guy at cosworth said, the cams wont work with the vvt system. so I think ill just stick with the usuall bolt on's for now.
dang. you kow your shit. more air means more fuel? dang. Im dumbfounded.
BTW, the kits come with new injectors. Fuel problem solved. Plastic intake is fine. We're talking 5-15 pounds of pressure. Not 50.
