[quote author=boardumb link=topic=68307.msg1179847#msg1179847 date=1170292826]
I had a couple friends install the draxas and they have no such CEL, in fact one of them has removed both cats...
In fact many people have taken out the second cat and they didn't get a CEL either. I don't see why removing a cat would cause a CEL, it's just a restrictive filter. You are making an assumption that because you removed a cat, the CEL showed up, when there are other reasons why the CEL was thrown. Again, search.
And no, the TB will not work, it's cable...
He has a CEL because of the header! It removes a cat. There are o2 sensors that detect if a cat is working properly remove the cat and they will let the ECU know there is a problem.
[quote author=janova777 link=topic=68307.msg1179840#msg1179840 date=1170292657]
how do i run the double O2 sensor fouler trick? Id rather try to get it turned off so that if something actually happens i know haha. that manifold is sick lookin too... its $695.00 right now, but its cool. I wonder if the cosworth TB would work with that manifold.
The Cosworth TB is cable and we have an electric TB, you are not going to get it to work without alot of work. Too much work, time and money in my mind to make it worth it.
