1 - 20 of 32 Posts
· Banned
so here is my situation. i just put in springs on wednesday, and installed corksport inserts roughly a month ago.
as of three days ago, there is a squeaking noise when i clutch in. in addition i get the squeaking when i have low rpms in 1st, and then add more gas quickly, i get the squeak, or when i accelerate fast from a standstill.
i hear the squeak even more when my car is on a downward slope, making me believe that the motor mount bolts aren't tight leading it to squeak and slide down a bit...
at first i thought it was my springs or f+/or r sway bar, but its not really a clunking and it doesn't sound like its in the rear at all, more concentrated right under the car.
or do you really think its the springs...i thought springs had a distinct sound...and when i go over bumps going slow and/or fast i hear nothing...its only when using the clutch
so you think i should retighten the motor mount bolts and add loctite (maybe should have done it first time) ? or is it something else
its really pissing me off, as im really anal about squeaks and everything needs to be perfect
oh and when i shut off my car...obviously my car was not moving...the squeak was evident....and i was in neutral with parking brake on, foot off all pedals
· Banned
Re: Squeaking sound when clutching in and giving gas and clutching out
actually i am 99% sure its the inserts making the slight squeak. ironically it only makes the squeak when it was wet, which was three days ago and yesterday, the days i actually heard them squeak. so is there a way to quiet them down by adding grease or something, or is that just the nature of polyurethane?
· Banned
hmmm i don't think thats the same noise.
what im gonna do is check to see if the motor mount bolts are tight...if they are then i might take the inserts out and see if it makes the same noise. if it stops the noise ill probably go with another aftermarket mount or something else altogether since i hate squeaks haha..but we'll see. hopefully the bolt is loose or something for my sake.
if i get new mount, which would be better medieval or cpe...heard both have minimal vibrations compared to teh CS inserts, SU mount, AWR mount and TRZ poly mount...
· Banned
still have this problem, and its ONLY when wet out....yesterday i was driving around and it would squeak when applying and reapplying throttle in 1st and 2nd gear....but today i accelerated the same exact way and i don't hear a thing...only happens when there is water on the road/rain....?
im assuming its the inserts, so what should i do, upgrade to a full mount? i might take out the inserts to make sure 100% that its that before i go buy a real mount...
[quote author=babypetit link=topic=137094.msg3007074#msg3007074 date=1237578523]
I was going to suggest you do that first, but you beat me to it. :lol:
I've had my inserts in for month and I don't have any squeaking problems with them.
take them out and throw them away and buy the darkstar mount. I had the inserts and after a couple months it felt like they didn't even exist. They did nothing for performance after a while. My darkstar mount gives no vibes once so ever. Its quieter than the CS inserts and when i shift, i deff feel that it does do something.
yep thats exactly what i am talking about. When i first installed it. It had slight vibes but even those vibes were less than the CS inserts. And after driving with it for a week. I had no vibes once so ever. When i had the CS inserts the cars dash vibrated. With this mount i got no vibration and people can't even notice i have a mount. My dad drove my car after and didn't complain once so ever, vs the time when i had the CS inserts he said "you made your car feel like its falling apart".
· Banned
Discussion Starter · #15 ·
[quote author=08mazda2.0 link=topic=137094.msg3007238#msg3007238 date=1237582975]
oh really which one did you get, because the one on their website doesnt look like the one they had in the previous GB:
http://www.darkstarmotorsports.com/index_files/Page1735.htm
ps. im also surpsied no one else has gotten squeaks. i mean these inserts are polyurethane, and i did some google searches and everyone says that this urethane squeaks like crazy if not greased properly.....
mine squeaked but very little and plus i always had my music on so i never bothered with it.
Yea there older style just looks nice this new one looks like the TRZ mount but they use the same material so you get the same results as the other model. I am guessing they did it to eliminate the 2 piece and make it cheaper.
Ya, I'd scrap the inserts. They don't perform that much better. And your car will vibrate like a mofo with the a/c on. I'd recommend that you get a rear motor mount. I have the street unit motor mount and the vibrations are minimal and they are much better than the inserts. If you've got the money, I'd go for the cp-e rear mount. Their side mounts are supposed to be a sweet piece of engineering, you can get those later down the road just to keep everything uniform.
· Banned
Discussion Starter · #18 ·
[quote author=manny link=topic=137094.msg3008180#msg3008180 date=1237612959]
wait so you've had the SU mount and the CS inserts, and you think the vibrations and shudder when starting from a stop are better with the SU Mount?
Yup. I had a the inserts for a few months, so I definitely gave them a chance to break in. I had no intentions of buying an aftermarket mount, but a local member was parting out and I couldn't pass up on the offer. They perform much better and the vibrations are significantly less whether you are idling with the a/c on or start off from a stop.
· Banned
Discussion Starter · #20 ·
hmmm sounds good...now i am not sure which mount to get. TRZ poly dogbone is too rough as ive heard, awr has bad vibrations...medieval mount sounds good, but they got rid of the aluminum version and only have steel...and i haven't heard any reviews, CP-E mount, but its hard to get one of those, and the SU mount, which everyone pretty much loves...
its weird the speed3 owners say streetunit mount has more vibrations and the CS inserts you feel nothing, but the mz3 owners say CS inserts are harsher than some of the real mounts....is this cause of the extra space in the mz3 mount, so adding the inserts makes it stiffer than the speed3 with less gaps in the mount?
1 - 20 of 32 Posts
