Ok, so I just had an idea and I want any opinions or general experience with corksports fmic. I personally don't like the way they set up the air intake, all the heat from the engine rises and gets sucked into the engine. So, most auto stores have spectre performance intake parts that you can use to build your own intake. You could cut the pipe that goes to the intake on top of the engine and route it downward with some of the parts from spectre and put a cone filter on it. It would suck up more cold air and clean up the top of your engine bay too. And if you bought an AEM bypass valve it would prevent you from sucking water into your engine.
