[quote author=SVTFtoSPEED3 link=topic=133982.msg2880912#msg2880912 date=1232577706]
6 hours?? Wow!! Was it difficult to get it just right? I found a place online they sell both 3M and VentureShield brands. The VentureShield is10% cheaper. Should I just go for the 3M?
http://www.nextlevelride.com/store/2009-mazda-mazdaspeed-3-clear-bra-paint-protection.html?productid=44588
yeah, 6 hours. (eat before you start, start early in the morning just in case it takes longer, definitely get somebody to help) it's definitely not easy. it takes patience and slowly working the pieces into place, use a lot of liquid to keep it from setting.
if you choose to install yourself, it's not going to be perfect. you might have tiny micro bubbles here and there, might not be completely centered. just don't try to be a perfectionist with the install and you should be good.
I'd go 3M just for brand preference as I know they make quality stuff. Also, that kit you linked is only for the bumper. You probably want to find a full kit (Hood Front, Side Mirrors, Fenders & Front Bumper)
this is where I got mine: search ebay for item# 150279952464
should give you: MAZDA 3 SPEED 2007 2008 3M CLEAR BRA PAINT PROTECTION
(it also can with a cd that had a video install lesson, so make sure to watch it and read the instructions carefully before you start)
when making the solution, don't use too much baby shampoo (like I did) because it will make the material too slippery and it will be difficult to pull it around the corner.
again, as long as it stays wet, you'll have plenty of time to work it around curves and corners. just make sure you are PREPARED with enough liquid, hair dryer, really sharp exacto knife, extra hands, warm sunny day, no wind (garage would be ideal)
good luck.
