ok i searched and read a lot of threads on this topic but i still have a few questions...
i'll first give you the background... i'm planing on getting a complete system for my 3... i have to buy all the parts from bestbuy up her in canada becasue i can get them at cost +10%... therefore my choices are limited... i'm building a single 10" custom ported box and doing the installation myself...
the sub i'm gonna use is a Rockford Fosgate Punch Stage 3... its a dual voice coil sub and it comes in either 2 or 4 ohm configurations... my first questions is which one should i get (2 or 4ohm) if my choice of amps is as follows...
Rockford Fosgate Punch P3001 (1 channel)
Rockford Fosgate Punch P3002 (2 channel bridgable)
click here for a comarison chart of the two amps
i'm a little confused because the sub has a dual voice coil and i don'l know if that means i have to connect them separately or if they share the same terminal... also i don't know if its better to run at 2 ohms or 4...
i found the following picture at one of the websites refered to by a thread on the tipic...
what i gather from this picture is that the dual 4 owm sub would require an amp running at 2 ohms and the dual 2 ohm sub would require an amp running at 1 ohm... is this right?
any input is appreciated... some links to some sites where i can learn more about this tuff would be great too...
thanks
thanks
