1 - 12 of 12 Posts
man you need to get a book called maximum boost..... if you read it you will understand why no one is going to give you an answer to this question........ There is a lot of math/experience/information needed to determine the answer to this question. If you want a simple version of the answer it is the lower the compression ratio the better on an FI engine.
[quote author=pinkcheese link=topic=136400.msg2939371#msg2939371 date=1234754169]
with 9 pounds of boost what would the safest compression ratio be on pump gas 91 octaine?
when you go forced induction it is extremely important to lower the compression for a good reason. the highest compression you would really want to run would be a 9:1:1 compression.(somewhere in this area. i personally am running a 9:1:1 compression and i would not go any higher than that.) you really do not want to go much higher with that. anywhere in the 8s are good as well. just do not run a higher compression or you can and will go boom boom :boom:[quote author=HIm link=topic=136400.msg2939385#msg2939385 date=1234754483]
get all of your information by reading. read some books. we got some people on the forums who will help you out. ive been learning and studying about force induction for about 3 years. i ve got still alot to learn but i also know somewhat about it.
i have seen MANY smal to mid sized turbo setups running 7 to 13psi with 10:1 compression. 9psi in an engine with 10:1 compression will make more than 10psi in an engine with 9:1 psi. assuming you take the proper steps and use the proper heat range plugs, the car is being cooled correctly, and you keep tabs on EGT and water temps with after market gauges i see no reason at all to lower compression unless the car is higher than 10:1 and you plan on a large turbo.
a t-25 or t-28 sized turbo will absolutly LOVE 10:1.
[quote author=classicaddict link=topic=136400.msg2940754#msg2940754 date=1234819554]
have you even seen what happens to a motor that melts because of high compression? i am not talking about throwing a rod either! you will need a near perfect tune out of hell to get it to run and not blow. the size of the turbo has nothin to do with if you will blow the motor or not. when you are talking 10:1 compresssion you may be referring to big block v8s. my buddy ran his 5.0 with a 9:5 compression
[quote author=jesusm3 link=topic=136400.msg2940811#msg2940811 date=1234821403]
i have a buddy running a t4 on a FWD sr20 with 9.5:1 compression at 13psi.
i have another good friend running an SC61 turbo on a nearly bone stock internal ed FWD sr20de at 9.5:1
turboing an engine with 10:1 compression has been done so many times its not even funny. and yes i have seen plenty of blown engines from turbo, normally caused by not monitering the engine properly or not taking the proper steps to keep it cool.
i stick by my origonal statement. i see absolutly no reason to mess with compression ratio unless it is over 10:1 and you plan on running high boost levels.
also, the size of the turbo has everything to do with it. that is a very uninformed statement. 10psi from t25 is much much less volume then 10psi from an SC61.......MUCH less. there for there will be alot more piston melting heat from a 10psi SC61 setup than a 10psi t25 setup. and oh yea.........many of the 10:1 setup tunes are a basic ecu daughter board install with an average base tune not much more.
You see what I mean pinkcheese? Not too many straight answers. There are a lot of variables that go into the tuning processes. Seriously though, if you pick up that book you will have a good foot in the door in understanding all things boost. I think you would be hard pressed to find anyone who does not love the text.
[quote author=classicaddict link=topic=136400.msg2940841#msg2940841 date=1234822165]
what throws a rod is not the fact of the bigger turbo. it part of it that is put into the equation but it is in fact of the tune ( you run a car that is set up @ 8psi and you go 12 or 14 psi you will spike and risk the chance of blowing the motor.) If your motor is running lean then there you go. boom boom is a very high chance. i am not saying it is not possible but it isnt very safe. you are right about the volume on a turbo but for our cars there is not reason to run a t25 or t28 really. there are guys on this forum who will back me up on this. ask jake about the t25 or t28.
but back on subject. anything is possible for us to do with compression but on a daily driven setup i would think twice about it. you are right with a 10:1 compression will make more power at 10 psi than 9:1 compression but you are also limiting the amount of boost you can run
there are so many things beside compression rations that are important
for example i've run 13:1 compression ratios with t4 gt35s on them. make GREAT power but without meth and racegas and being careful with timing you can go bad QUICK
now for people who will run on this platform I advise to lower the compression to about 8.8 or 9.0. Without the control of timing you don't want to turn up the boost above about 12-13 psi either. You can run 9.5:1 safely but without the control of timing you gotta determine what you feel safe doing. Just make sure your setup is consistant with what works. Low compression more timing more boost. Higher compression meth higher octane less boost less timing. Etc.
[quote author=jesusm3 link=topic=136400.msg2941021#msg2941021 date=1234827812]
i dont know about this forum and t series turbos but that is what i am familiar with so i used that as an example...........you are going i circles.......you just backed my statement up by saying if you run lean. the larger the turbo the more air per PSI it puts out.....more air means more fuel is needed. there for with a large turbo you need larger injectors and a higher capacity fuel pump (255lph) and obviously a tune. but you are taking this tune thing to far.....not every setup requires hours of dyno time to perfect a fuel map. actually this is normally only done when trying to tune the car to the edge. hell.......you dont even need a dyno to make a car run safely. a wideband and a tuning program is all you really need, if you see a spike fix it. however this way you will not squeeze every ounce of power out of the engine..........but you make power by tuning lean. therefore you need to make a choice......fast? or reliable?
[quote author=jhershorin link=topic=136400.msg2941482#msg2941482 date=1234837796]
DAMNIT! i forgot these cars cant have the base timing changed much :( now i feel silly. i missed a huge tid bit of info lol.
There was guy talking about dual mass flywheel was not bad price from Mazda. And though the only place he could get one was from Mazda. However you can buy Luk dual mass flywheel from Amazon for 263.47$. And there are other places to get things from.
1 - 12 of 12 Posts
