1 - 12 of 12 Posts
It’s been -20c the last few nights and I notice the 3 seems to have to turn over a few times before it fires... where is some of my other cars fire rate away. Also it seems to rev at about 2500-3000rpm for about 2min before going down to 1500rpm then about 5min later 750rpm I have the 2.0 Standard 05... Anyone else’s having this issue or is it normal for this car? Or should I take it in to get it looked at?
The car shouldn't be hard to start, but it's normal for it to rev high while warming up...my 2.3L revs at about 2k RPM for a minute or so before settling down. I think our engines do that because they're smaller and have aluminum blocks, which shed heat faster than iron blocks. Bigger engine = quicker warmup.
Mine has definately felt the cold freeze these past couple days. It is also hard to start, but after a couple turns, she's ready to roll.
mine had a hard to start moment today. It was 8*F (what is that? -5C?) The starter had to work for it's money before the engine started and the revs jumping up (which is normal for this car in the car)
G
My 2.0 was a little grouchy on cold mornings too....I don't think it's a cause for worry. Every car is programmed a little differently for cold startups. My Frontier turns MAYBE one revolution and rockets straight to 2000 without a hiccup, where my 3 was a little groggy at wake-up time. It's actually better to take a few turns before firing, as oil has begun to circulate before rpms rise.
I SOMETIMES have 2 noises that pop up upon startup cold or warm weather:
Belt driven noise and what sounds like internal engine lifter, valves?
Any ideas?
Is it an issue or is it moisture causing the belts to act up:?:
oooooh, sometimes I hear clicking after cold starts. :)
and Sometimes it takes about 5 cycles before the engine starts...
Nothing too worried.
Twice, my TPMS went off because it was cold enough to drop my tire pressure.
When its cold I start mine the same way...I turn the key and it starts.... :dunno: I guess i dont see a big deal with starting a car in the cold. The procedure is the same... :?
The colder it gets, the longer mine typically takes to start up and get down to around 1000 RPM. Then it's a big sluggish for a while until it gets nice and warm. That's just the way it is, it seems.
Man this really pisses me off. Before my old car was stolen, I picked up this amazing extension cord. The kind that never gets hard. Before even using it ocne, the damned weather got warm (thank god!!) then the car got stolen spring-summer!
Mine sounds just like truf's. Well, 1-3 turns and she's up to 2k. Holds for a min and it's wakey wakey, eggs n bakey!
1 - 12 of 12 Posts
