i have a 2008 mazda axela 1.5l hatchback and want to take out the stock air intake and replace it with a cold air intake. how do I manage it without breaking anything
I thought it was just an intake with a filter but I wanted to relocate it entirely so that the airflow doesn't go on top of the engineAre you aware your car came from the factory with a Cold Air Intake?
In your case that's pretty much it. The newer Skyactiv engine had a little more thought into the air intake/filter system but even they have short comings not cooling the intake air charge if the throttle plate % was less then 45%. The engine compartment heat at low vehicle speeds would heat the intake charge. At best the intake charge would normally run about 10 degrees higher than the ambient temperatures. More so during summer months and the use of the AC.I thought it was just an intake with a filter but I wanted to relocate it entirely so that the airflow doesn't go on top of the engine
What is it you hope to gain?
