my 2.3L MTX has just recently started a mild clutch shudder (or chatter?) upon 1st gear takeoff from standstill. it started at about 5000 miles, and now with 6300 miles, it is definitely noticeable, but not yet bad. but i am worried it will get worse with time. it only happens once the engine is fully warmed up, and only on first gear clutch takeup from standstill. i have driven MTXs for 22 years and have never worn a clutch out. i have even gotten 180,000 miles on original clutches. so it's NOT my technique at question here. another thing i noticed is that if i give it a little more gas than normal (about 1500-2000 RPM) upon initial takeup and make the takeup a bit more aggressive than normal, it's still very smooth. but normally i do 1st gear clutch takeup at about 1200-1300 RPM and am very good at minimizing clutch disc friction at takeoff. it's at those lower RPMs that i notice the shudder. i notice it especially when i am doing very slow maneuvers, like parallel parking, where you're modulating the clutch a lot while not really moving much.
any thoughts? how long is the stock clutch covered under warranty? could it be something other than a clutch component (like a loose/broken motor mount causing the engine to shudder)?
