· Banned
ok while turning i hear a clunking sound come from the rear of the car. i took everything out of the trunk including the spare... i mean everything! i checked underneath the car didnt see anything loose or close to the suspension, i checked behind the bumper, the inner fender wells everything... does anyone else experience this? please help. by the way this is a 2.0 2005 mazda3 sedan with 17" mazda6 factory alloys and yes i checked to see if they were hitting anything and they arent
I have a 2005 GS (i model equiv.) with 15" alloy wheels, and I will occassionaly hear a thud type sound if I take a tight turn at high speed. I honestly think it's the suspension getting near it's limit as the weight of the car shifts dramatically when pulling maneuvers like that. I also hear a similar sound when braking very hard and then finally coming to a stop suddenly, again I believe it's the large movement of the shocks causing it. And going over speed bumps, even at low speeds seems to cause a creak type sound as well.
I think it's normal, and probably to do with the shocks reaching their limits. Now if you're taking a gentle turn at a slow rate of speed, you may want to consult the dealer, it should still be covered under warranty.
