1 - 20 of 32 Posts
I had visually checked it from the bottom several weeks ago, and it looked okay. But after reading about even more failures recently, and given that I'm going to the track next weekend, I decided to physically check my motor mount bolt.
I put the front on ramps and removed the battery and box. I got underneath and removed the undertray, but couldn't locate the bottom of the bolt (or so I thought). Then I put the jack under the transaxle and jacked up a bit until the car started to lift. I didn't see the head of the bolt pop up, so I thought it was tight. Then I turned the bolt counterclockwise, carefully noting the amount of torque required to break the bolt loose. It was maybe 30 ft-lbs! I gave it a couple of turns and noticed that the head of the bolt was not moving up, which it should have been. I pumped the jack handle two more times, and the bolt jumped up quite a bit, more than what I thought I had loosened it. So I tightened the bolt back down, and it definitely took more turns to get it tight than what I had turned it loosening it. [If it isn' clear, what this means is that, unfortunately, I don't have visual proof that the bolt was loose, though I am convinced that it was.] I got back under the car and realized that it wasn't that I couldn't locate the bottom of the bolt earlier, I just didn't recognize it because it wasn't sticking out as far as it was when I visually checked it several weeks ago.
I then removed the bolt completely and looked at everything. The bolt did not have loctite on it, and there were some small bits of loose metal in the threads. I looked in the hole and saw that the threaded hole in the transaxle was not centered with the hole in the mount itself. It was as far off toward the front as it could go, probably due to the angle of the car and the jack. In the metal sleeve in the mount (this piece is unthreaded) I saw marks corresponding to the threads of the bolt when I loosened it. This binding between the bolt and the sleeve could have been the only reason I felt any breakout torque at all. The threads in the aluminum piece below looked to be in reasonable shape (can't see much down there). The threaded hole is about an inch long, which should be plenty of threads if they are all engaged.
I cleaned the bolt, put some red loctite on it, and tightened it to 75 ft-lbs.
The car has about 3200 miles on it. I bought it Nov. 10, but it had been on the lot for a couple of weeks before then (where do I find the build date again?) Most of the time, this car is driven fairly easily.
There is something else. As long as I've had the car, there has been a low thunk over bumps. It sounded like it was radiating from a large piece of sheet metal with some weight to it. Imagine being inside the car and someone pounds the side of their fist on the hood. It wasn't a sound that a car should make. It was easiest to hear when going over a speed hump (hump, not bump). The sound was made just when the front wheels transitioned back from the hump to the road. This is what prompted me to visually check my motor mount a while back. In a way, I wanted to find something loose so I could have a fix for the thunk, but it appeared to be tight. On the way home tonight, I didn't hear the thunk during the entire trip. I'll need to drive on more familiar roads for a bit to really know.
Go check your motor mount, or take it to the dealer PRONTO!
daum... something ive been meaning to do
if I had a nickel for every time I told myself to check it already....
[quote author=Mattleegee link=topic=68660.msg1187033#msg1187033 date=1170647056]
Well if i had a nickel for every time i read a thread involving it, i could buy a double cheesburger by now
its threads like this that scare me considering I have a 3 hour drive home from my dealer whenever it comes in...
[quote author=Mellman link=topic=68660.msg1187038#msg1187038 date=1170647252]
Yours should be ok, some people reported finding their bolts with loctite.
[quote author=CosmicBlueMS3 link=topic=68660.msg1187023#msg1187023 date=1170646754]
If only weather wasn't so cold I'd be doing in it in heartbeat too.
I gotta get my ass moving and check that damn bolt.
MUST THE LOWER PAN be removed to clearly see the bolt position and how loose it's become?
The most annoying thing is that you shouldn't have to be worried about going out in the cold to check if the car was f**ing built right!!!!!!!
They should not have sold them like this, they need better quality control, and it should not be up to us to either fix it or check it!
End of rant, since none if this will happen I guess I'm just going to have to deal with it. However, I will say that I was worried about buying a Mazda because of quality of workmanship issues and it seems they have lived up to my fears. Even if the German car has electrical issues, at least the damn thing stays bolted together.
[quote author=leofaye link=topic=68660.msg1187050#msg1187050 date=1170647675]
no doubt, its just too damn cold to check, someday ill have a nice garage, but right now the car is sleeping soundly in my portable "temporary" garage. Im not driving it now, so its not a big deal, but Im dying to know whats up with it and get a big gob of red locktite on it asap.
the thing is though, how do you make sure the dealership doesnt just do a visual inspection, see the bolt doesnt look raised, and call it cool? mazda has been less-than-forthcoming with this, and i have a feeling the dealer wont have a clue about this. im 95% sure i'll be the first speed3 thats been in the maintenance bay (my dealer has sold 3 to date. maybe 4). i just wish i could just go back n use their tools myself so i know the job is done right. i'd love to do it myself, but i dont have a free weekend for weeks, and its too damn cold to get out and do this after work.
this sucks. :(
Well the good news is that you can have the dealer "check" the mount and make them wright on the receipt exactly what they did. ie. visual or torqued with the pressure off the mount or on the mount. Then when it breaks you can show that to the Mazda lawyer you settle with in court. I can't say enough what crap this is that our cars are doing this and there is not guidelines from corporate. I'm pissed, but that is not to say that I'm surprised by the lack or response, info, etc.
Emailed the manager of the service department. told him that there are four known cases from various web boards (with photos) and i wanted to know if there has been a TSB issued about the problem.
he replied that he knew or heard anything about it, but said i can bring my vehicle down and they can check the mounts/bolts.
kind of wierd, think that mazda should inform the service managers about this problem. there is potential for serious accidents/death.
i will have them check my mounts/bolts when i go for my next oil change.
Discussion Starter · #13 ·
Don't know what you guys are whining about, it was around 60 deg. here last weekend 8) Washed the car, too...
I fully expected that I was wasting my time by checking the bolt. I was really surprised to find it loose.
If anyone else checks it themselves, be sure to jack the motor up enough to get significant load. This will help ensure that the bolt pops up if it is loose for a visual confirmation.
60 degrees... you suck!
the heat in my office is broken today and its a balmy 48 inside! outside its officially 11 degrees and with windchill its 3
I'd check mine, but it's -40 Celcius here with the wind chill!
I'm also waiting to change my shifter bushings!
I will make mine part of the dealer prep.
I am still a little leary of the locktite being a fix. i think the fact that these seem to happen early on is a testament of something. if locktite does not fix it, it will be broke again in a short time.
Crap!
I have that same thump when going into the parking lot near my work (it has a bump to get in). Now I am really worried. The dealership is over 3 hours away!
I have to get the oil changed, CEL Purge Valve Fixed, CEL 2005 Fixed (air valve), and now the Motor Mount Checked and tightened.
Crap!
Thats a big list of things to do, and no time to go :( atm.
*EDIT: So how should I go about telling them to fix it? Tell them to tighten it and I heard from a forum alot of people's Motor Mounts are loose? Also should I tell them about adding a locktite?
[quote author=c0ldFuzion link=topic=68660.msg1189731#msg1189731 date=1170779220]
Crap!
Crap!
No dealers near me either. I live in one of the biggest cities in the world and the Manhattan Mazda dealer doesn't do MazdaSpeed. Go figure.
[quote author=TrueRedSpeed link=topic=68660.msg1190086#msg1190086 date=1170789756]
Not many city dwellers want MT.
1 - 20 of 32 Posts
