1 - 5 of 5 Posts
So recently, my check engine light has been coming on. I'm driving the 2004 2.3L. I took it to AutoZone and they told me it's coding two things:
P2187 (twice)
Definition: System Too Lean at Idle Bank 1
Explanation: Failed MAF
Probable Causes:
1) Low Fuel Pressure
2) Vacuum leak on engine
3) Failed HO2S
and then:
P0455
Definition: EVAP large leak detected
Explanation: The ECM has detected a large leak in the EVAP system during a system monitor test
Probable Causes:
1) Defective, loose or missing fuel cap (already checked, that's not it)
2) EVAP canister broke, hose cracked or not connected
3) Purge or vent solenoid defective
4) Vacuum leak at engine
I'm not really sure what to do from here. So I bring this to you all. Is there anyone who can help?
It is your purdge solenoid. It is stuck open. causing a lean at idle and the evap code for the large leak. you can usually just tap it and it will shut. But this is a very common problem for the 3's and the 6's and well anything with the purge solenoid that is why they changed them on the 08.5
so what ended up being the issue for you? i have the same problem on my car but i just replaced the solenoid with a brand new one so thats def not it
Posted by: brownac5786
« on: January 22, 2009, 11:26:07 pm »
Insert Quote
P2187 (twice)
Probable Causes:
3) Failed HO2S
and then:
P0455
Probable Causes:
1 - 5 of 5 Posts
