1 - 14 of 14 Posts
I have a 2008 Mazda 3 hatch with a 2.3 I4. Whenever I’m on the highway and I cruise towards 60 the car makes a huge clunk and the car continues to drive perfectly fine after. But this is no ordinary clunk, it’s a hard jolt forward. Best thing I can think of right now is the throttle body.
does it do it in a lower gear, ie higher rpm at same speed, or rpm related
does it do it when you decelerate through 60
manual or auto
we
manual or auto
It’s in 5th gear. The car steadily holds 2k rpms. It happens when I decelerate as well. The car is an automatic
Discussion Starter #4
we
The car never does the hard jolt when going under 60. Only happens on the highway. I can’t find anything similar about this situation.
I presume the Check Engine light (CEL) isn't illuminated... However, can you scan for OBD-II codes immediately after a drive when this happens, so you can assess for pending codes [from the transmission]? A pending code wont set the CEL. I think this seems more like a transmission or TCM issue, rather than the throttle body.
Discussion Starter #6
Well there was a CEL but it went away on its own. I have to wait until Monday to get my hands on a code scanner. I’ll come back here and posts the codes to get an opinion from you all. I appreciate the responses!
FWIW, I believe every major parts store in the US offers free OBD-II scanning, a courtesy and way of drumming up business. If a CEL gets set, or the "jerk" happens before Monday, consider stopping by an auto parts store to have them scan for pending or set codes.
SAME ! And my clutch Master cylinder just went out I think , im just touching 130k
Well, a manual transmission may have a different issue all together. However, in the off-chance that these are related, have you [both] ensured that your motor mounts are good? If you're getting a unsettling jolt without clear, forced RPM or speed changes, perhaps something is up with the mounts that manifests with the mix of vibrations and torques at particular speeds.
Hello, Check this video out, and see if you have the same problem
2012 Mazda 3 GX MT5
Sounds like the TCM ... but to be sure ..tie down the dead body in the trunk when you are doing that get away
I'm sure you are already in 5th gear by the time you are at 60MPH, but just wanted you to be aware that IF the hard jolt is occurring when it shifts between 3rd to 4th gear (known as "shift shock"), then that is likely due to a faulty transmission which wasn't fixed until the 2009 model years. See this TSB: http://noes.net/05.10.10.pdf
Note that there is also an aftermarket toolkit to fix a transmission with this issue, shown here: 4F27 | Northland Automatic Transmission Service Inc.
The issue is caused by a servo pin's bore hole getting worn.
1 - 14 of 14 Posts
