I'm experiencing major rusting issue with my wiper assembly.
Is it possible to remove the assembly to have it spray painted and any particular spray paint brand that needs to be used?
Any help is much appreciated. Thank you! :p
if you are referring to the wiper arm, then yes it is removable. at the very base of the arm (opposite end with wiper attached) there is a plastic cover that goes over a nut. you may have to open the hood to access the nut, after u remove the nut you will have to remove the arm from the post be means of a "battery terminal puller" or carefull use of a flat head screwdriver. (the arm is slightly pressed onto the post that sticks up)
