1 - 13 of 13 Posts
I just put my fujita intake in my 2005 mazda 3 23sp and the car is having troubles staying idled and in 4th gear going about 45 mph, when i step on the gas in struggles to get going. ooo and also i had a CEL but i reset the ECU and it has been running for about 10 miles with it off know. sooo does anyone know what is going on?????
I mean this is the second time i have put it in, because the first time the problems started like this and then they got worst. To the point where my car would die waiting at a stop light and when the car did idle the rpms would bounce from around 750 to 1500. So i dont know whats going on ha ha ha yes i know im a noob but if some one knows whats going on or had the same problems, help would be great..... thanks
double check that the hose clamps are tight and you're not getting a leak.
did you connect the breather hose?
Discussion Starter · #7 ·
How long have you had yours in for????? and what model do you have (car)??? and i just dont understand how most mazda 3s the CAI work fine and some dont...... :?
The clamps are extremly tight so i dont think thats the problem and ha ha yea im not that much of a noob. I put the breather hose on.
yeah same here i have everything done. Even when istalled i reseted the ECu and never have had a CEL so im not sure what to do,.
[quote author=darre146 link=topic=70647.msg1237458#msg1237458 date=1172621509]
didn't mean it that way... ;)
it may be the MAF sensor itself...it's very fragile. When you swapped it over...did it drop or get bang'd around? You didn't tighten the 2 screws holding it on too tight did ya? Also, is it fully seated on the pipe? with no air leaks?
Well for me the MAF sensor is fine at least i think the screws are in nice and there dont appear to be any leak holes. I baught a BOMZ intake from ebay about 5 months ago and it was giving me this same problem so i thought it was the intake so i went and baught the simota intake and i still get this problem
Discussion Starter · #12 ·
hahah no its cool man i was joking. but no i was very care with the MAF and i put the screws on tight but not too tight..... so yea.... and the MAF sensor works with the stock air box so i pretty sure its working fine.. so i dont know.
1 - 13 of 13 Posts
