1 - 7 of 7 Posts
iono if this is a dumb question or anything, but is brake fluid clear? because the container of brake fluid in the engine bay looks to be empty compared to the other fluids. i cant check the level of brake fluid. and is there a brake fluid light on the instrument cluster to know if the brake fluid is low or anything?
pretty sure its amber. All it is really is hydraulic fluid being empty is FTL get some in there asap! I mean do you see fluid in there at all?
no. it looks like its empty, but my uncle says it might appear clear. and the brakes work fine too. and no lights have come on the instrument cluster yet.
[quote author=as1an_1nvas10n link=topic=138685.msg2988708#msg2988708 date=1236815571]
The brake fluid contained does appear clear, it is hard to see the fluid, but it should be there, look closely.
Just an FYI for people goin through this:
I just went through this when i went out lastnight with a flash light to check it. I looked at reservoir and thought to myself, where the heck would ALL of the fluid go? why cant i see it? Eventually with the light hitting it just right and shaking the reservoir i was able to see a little shimmer right at the max line.
If it gets low you will get a warning light on the dash, though you should still visually check it occasionally.
1 - 7 of 7 Posts
