1 - 8 of 8 Posts
Hi this is my first post:
My question is, what exactly is the bolt pattern of the Mazda3?
5x100?
5x114.5?
Couldnt find a f'sure answer.. thanks! :)
Oh, by the way.. the wheels are 40mm offset, will this fit?
According to the math, it should be fine.
The stock wheel is 6.5" wide (16 or 17"). Your wheels are .5" wider and 12.5mm negative. .5" is 12.7mm.
Add the additional negative to the width of the wheel, and you get .9" away from the hub.
Quick measurements show the stock wheels sit in the fenders about 1.5"... Maybe more. .9" will get you closer without rub, imo.
1 - 8 of 8 Posts
