1 - 20 of 86 Posts
Hello everyone, my name is mike, I picked up a 2004 Mazda 3s for a good price, 3rd gear is blown, and the engine rattles to hell at around 3.5k RPMs, but in all, the interior is very clean, the car all around doesnt look bad at all, 173k on the clock, and it came with Quite a few goodies, and looked like a good opportunity to 1up my neighbor on his mediocre mechanic abilities (Has a shop, a lift, tons of tools, Cant fix anything right, thinks hes Mr. know it all)
17" Advan Racing RG2 Wheels
MSDS 4-1 Headers
EXEDY ZF501 Chromoly Racing Flywheel
K&N Intake
Swap Purchase List:
2012 Ford Fusion 2.5 Engine $425 + $30 gas to pick it up
2004 Mazda 3 5 speed transmission 66k miles $422 Shipped from Canada
Crankshaft bolt ~$15
Mazda stock code- LF0111406
Flywheel bolts ~$6 x6
Mazda stock code- LF0111511
Axle bolts for 04-05 ~$12 x2
Mazda stock code- 9YA021083F
Crankshaft friction washer ~$13 x2
Mazda stock code- L3H511407
Ford code- 1S7Z-6378-AA
Camshaft friction washer (only required if you remove cam sprockets) $13 x2
Mazda stock code- L3K912429
Mazda PCV Valve $15
EXEDY MZK1003 Clutch Kit $ 154.79
MOOG RK620040 Control Arm $ 58.89
MOOG RK620041 Control Arm $ 59.79
MOOG K80235 Stabilizer Bar Link $ 23.79 X2 = $ 47.58
Shipping Ground $ 16.98
it has some shifter mod, im not sure of what, but the gears are VERY close together, I like it, i dont think the missus will like it tho, LOL, there are probably other mods, And after looking at the power output of the 2.5 with everything ill be putting into it, it looks like it would be fun when its done
Aaaaaand How about this one?? Haha..... im shocked it held
And much much more to come, i just ordered my 2.5 with 45k Miles and it is about 100 mile drive away
Im debating on what to do about the transmission, because i can find one from canada with 66k miles for $420 delivered to my shop, or pull one locally and hope it works for about $150, IF i can find one, either way i need one because the one i have is from a junkyard and looks much much dirtier than the engine (not taken care of)
I need to get this going sooner than later because my DD is Cursed and it broke down for the last time and im currently using my work truck, which ALSO needs another transmission
wtf on that bolt though.....
My vote is go with the transmission with likely a return/warranty option and is ready to go, vs having to pull from a junker.
The transmission may have a short shifter plate on it like the JBR or Corksport one.
Don't put it on the new one. They're common to binding the selector, and yeah... means you miss shifts all the time.
A shorter shifter like the TWM is all the car needs. Along with solid shifter base bushings.
Discussion Starter #3 (Edited)
Razo shift knob, And im assuming this is an after market shifter of some sort?
ive only skimmed through the FSM a few times, Is there a section with all the engine bay wiring? i looked briefly and didnt see exactly what i was looking for, I ask because there are a bunch of little random grounds all over the place which look Added , EDIT: Just realized the shifter has TWM cut out in it.
The shifter linkage lines connect to the plate that shifts on the transmission, if that looks OEM, it may just be so worn out that you had issues regardless of the shifter.
Either way, solid bushings on the shifter base will give a huge improvement after a [working] transmission.
But since you have the TWM already, that should also help.
It's just the fact everything is made of plastic, and it all wears out over time, but the TWM's ball at the bottom is slightly larger than the OEM plastic ball and helps fill the gap a bit more... and doesn't flex.
But the TWM isn't really regarded as being 'awfully short' of a throw.
When attached to a short shifter plate... then yeah, it's stupid short.
Discussion Starter #6 (Edited)
Where would i find the Engine/o2/sensors wiring harness Diagram? Ive been searching all day and cannot find the layout of the engine harness (Probably MY Error, Lol)
EDIT: I just ordered a Factory 2004 Mazda 3 wiring diagram Book $18.95 shipped..........
EDIT #2: Just ordered Timing tools, Balance shaft delete & a 5spd transmission with 66k from Canada for $420 shipped to my office =)
Discussion Starter #8
Heres the 2.5 on the Engine stand........ Sooo clean, NIIICE............
sorry for the fuzzy pic (idk wth is up with my phone)
CLEAN, my jaw dropped when i popped the cover off....... looks NEW
interesting cover over the fuel rail.
Also, that isn't a hole in the intake manifold is it??? On cylinder 1?
If so, complain about that.
You don't want to use your 2.3 IM on the 2.5, the 2.5 is a few mm taller in the ports.
Discussion Starter #10 (Edited)
from what i read in the swap thread and what everyone else said was to use the 2.3 IM and Milans adapter plate
what your seeing on the intake is a Defect in the picture, how, idk, but thats not on the intake LOL
Ah! Must be a ceiling lamp or something then lol! It looks almost like a screwdriver punched a hole into the thing!
I've heard you have to as well, but I honestly haven't seen a reason why.
But I do know for a fact the 2.5 intake ports are much larger! And certainly don't match up with the 2.3's IM ports.
Discussion Starter #12 (Edited)
Look at it closer, it finally dawned on me what it is, a big ass oil finger print
Heres the Balance shaft Delete in place, Holy crap that thing was heavy, ill do without just for the weight LOL
The 2.3l intake will match the throttle body mounting. As of yet no spacer/adapter exists. Even if an adapter was available the Ford throttle body would be incompatible electronically. The adapter would need to adapt a Ford 2.5l intake with a larger TB ID to an MZR 2.3l TB with a smaller ID which would also limit airflow.
There is also speculation that the variable length runner design of the 2.3l intake is enough of an advantage over the port matched 2.5l intake to make the port mis-match negligible.
The "2008milan" adapter works perfectly to align and seal the 2.3l intake flush with the 2.5l head.
Those of us who have completed the swap and are running our 2.5l engines on 2.3l ECU are mostly looking for longevity from the swap not performance. Although, butt dynos are telling us there is some muscle there, it's just not optimized.
That was before we knew the stock SPeed3/6 throttle body bolts right up to the 2.5 intake manifold, and plugs into the 2.3 electronics. As this way you wont be having to worry about mis matched ports at all, and can actually use the 2.5 intake manifold. :)
Do you have a part number on the throttle body that fits up to the Ford 2.5l manifold?
I would assume not wasting time on the Fusion TB, I'm fairly positive I recall seeing someone saying it cannot communicate with our ECUs, let alone I recall it having a different connector.
Discussion Starter #17 (Edited)
Heres how the engine sits until the washers and bolts arrive (i did clean up the water block after i took the pic, didnt stand out until i took this pic, then i realized, damn thats caked up
I need to buy a pigtail connector for the solenoid, mine was cut so short to the connection i cant use it, Part # WPT-1251
Its whatever is found on the Mazdaspeed3's, and Mazdaspeed6's. :) Id just check Ebay. They can be found even cheaper then how much the intake spacer is.
Stock 2.5 TB has the same connector, But the actual internal wiring is different. Hence the 2.5 TB doesnt work. And you cant use the 2.3 TB cause its a different physical bolt pattern on the 2.5 intake manifold. Using the Speed3/Speed6 TB, Which shares the 2.5 Intake manifold bolt pattern, and also shares the 2.3 electrical plug, with compatible wiring. Hence my earlier comment yesterday. ;)
1 - 20 of 86 Posts
