I just got the Buddy Club Condenser Kit last weekend and today I popped the hood to just check on it, too make sure everything was in place. When I popped the hood I smelled burning rubber. So when I pulled off the engine cover I noticed the ground wire from the condenser to the strut tower was laying on the header heat sheild. Sure enough the spot it was resting on had melted. I thought I got rid of the slack by using the zip ties in the kit, but obviously not enough. Now it only looks like the rubber casing is melted and about a pin-sized place is too the copper wiring. My question is should I leave it attached and just secure it better, or should I just take it off and leave the TB and fuel rail grounded? Is there a way to order just that wire again? Thanks for the input.
Edit: Is anyone just running the TB and fuel rail ground, if so does it work good for you, or is there a difference because all three aren't grounded?
