1 - 11 of 11 Posts
So after finishing my HID install, I decided to put on my lamin-x film. Here are the results...will these spots go away or I'm screwed?
i dont think it will clean up...
did u install them dry or with liquid?
I redid them just now...it turned out better than before. I will wait after a week to see if it'll clear up.
looks like you used too much soap in the mix - it will take longer to dry but eventually it will go away. just make sure that you squeegee as much liquid out as possible.
Any bubbles leftover you can pop with a thin needle and push the rest out.
LOL shouldn't of touch that if you didn't know what you're doing...that's some bad work you got yourself there.
You shouldn't have to wait for them to clear up because they won't.
yes it should clear up - I applied on a brand set of Audi TT headlights and its looked like crap...took 2+ weeks to clear.
The fogginess will definitely clear up, It might take a week or two but it will. You can speed up the process by parking it in direct sunlight. Also if there are air bubbles they will go away as well over time. Be patient
1 - 11 of 11 Posts
