[quote author=dmention7 link=topic=66683.msg1144463#msg1144463 date=1168541779]
The only problem I had with running it through next to the light bulb was that my stereo plug was too large to fit through that opening. I guess that may or may not be an issue, depending on what particular cable you have.
I have the same problem. The ashtray is actually two pieces when you pull the red insert out; there's a horizontal seam running across the back, with a gap between the two (the bottom piece sits a little further back than the top piece). I ran the cable between those two pieces, so it comes out right in the middle of the back of the ashtray. I plan to drill a hole in the same spot on the red insert so I can snake the cable through. If anyone wants, I can take a pic when I get home later.
