[quote author=icspots link=topic=65885.msg1129214#msg1129214 date=1167759564]
Some questions:
-Are you charging the Mp3 player while you're playing it?
Because i do not have my mp3 anymore and switched to Phatnoise i do not use it with Aux Mod, but i did not charge it while playing it "my mp3 player was not capable of doing it".
-Same question for you CD player? (I assume that's a discman type, yes?)
I only have used it once, and it was with my buddy's CD player
-Is your sirius an auxillary unit, e.g. a sirius starmate?
Whats the difference? Its sirius S50
-Does the sound continue happening if the engine is off?
When engine is off, no whinning noise at all, but at starting it i hear that whine pretty bad, the higher RPM the louder "kinda A gas SAVER REMINDER ;(". I have noticed it does it with anything i connect the AUX wire to, even with MP3 player, but with MP3 player its noticable when i play music at volume 5, which is very quiet and buzzing noise was killing me, now when i connect it to Sat Sirius the lowest i need to have my volume is 10, cause the buzz whinning noise is much louder.
-What do you mean by you have ground loops? Do you mean you have ground loop isolators?
Yes thats what i meant. I have an amp connected to my stock stereo headunit and because whinning was an issue i got myself those ground loop isolators. "Schosche".
-Is the AuxMod seated properly?
Yes, very firmly.
As long as you can figure out what's causing the noise then I would most certainly say to not go with a FM transmitter as long as you can mange not using one. I mean it would work, but for the most part they sound so much worse than a direct line.
Well i think it could be cause i got a bunch of wiring for stereo involved and crossing, i will try to rewire the wiring and see if the problem will be solved. But this Whinning RPM noise is always there whenever i connect anything ot it.
