Autocrossed my MS3 for the first time over the weekend. It had been almost two years since I last autocrossed regularly. Back then, I was driving a '99 Miata in C-Stock. Quite a change going from a 2300lb RWD car with 138bhp to a 3100lb FWD car with 263bhp. While I was nothing short of rusty, I got a kick out of driving the MS3 aggressively, even if was only in a parking lot full of orange cones. I ran the car in STU because of the wider wheels I'm using; 17x8" Kosei K1-TS with 235/45-17 Kumho Ecsta MX tires. I also drove with the DSC and traction control completely off.
Pros:
-The power. Even though boost in 1st and 2nd gear are electronically limited, there was still adequate power on tap.
-The brakes. They stop the car like nobody's business.
-The chassis. Very civilized even through all the transitions.
Con:
-Turbo lag (or the perception of it): Coming out of those slow corners, it seemed like an eternity between the time I put my right foot down, and the time boost kicks in. By the time the car gets moving, I already have to brake for the next corner. Probably more to do with my driving than the car itself.
-Perceived Brake lag: It feels like there's a delayed reaction between the time I stomp on the brake pedal and time the car begins to slow down. It's unsettling.
-Torque steer, but that is a given with high-powered FWD cars.
-Engine mounts: These cars really need stiffer engine mounts if they are to be tossed around an autocross course or a road course. On my final run, the car popped out of gear ruining my chance for a better time.
All in all, I'm looking forward to improving the nut behind the steering wheel, and that Cons list may get shorter.
Pros:
Con:
