I just did the 3-4 flush for the first time at 48000 miles. Black does not describe how dark and spent the fluid was :shock: I then saw on this forum you can use the pump on the car to expel majority of the fluid. So just a couple of quick questions.1, i need to do the 3-4 flush before I hook up the hose to the pump so it pulls fresh fluid? expel 3 quarts and refill,expel three more and fill and continue until fluid runs RED? And should the filter be replaced or just wait, my drain plug had no metal or build up whatsoever. Thanks
