I have a 2008 Mazda 3 Hatch, I installed Maxspeedingrods suspension on it because I got it for practically free and my stock shocks were blown. My mechanic tells me I need camber plates inorder to align it properly, but I see virtually no options in terms of front camber plates. Does anyone have any recommendations?
How far off is the alignment? You shouldn't need camber plates to align it unless your camber is really off. Even then, your car has camber and caster adjustment from the factory, you just loosen the 3 upper strut strut mount bolts and slide the strut in the direction it needs to go. Bad toe settings will wear your tires out far faster than a little bit of excessive toe angle.
