o.k. so i was doing the coolant bypass mod today when i dropped a damn rubber stopper into the area under the tb. so i take out the filter box and then i am able to reach it, also it makes it much easier to get to the lower tube on the tb. well, unfortunately, i did not put a rag in the tb, b/c i thot i was only gonna be in there for a sec to grab the plug, and a few drops of coolant, i wanna say no more than a teaspoon, but i am not exactly sure how much, dripped into the tb, i guess from my hand or a passing dripping something, it's weird b/c there was almost no leakage during the mod, just a little from the bottom tube. i cleaned the tb as much as i could and quickly put everything back together and started the engine to check for leaks and to listen for anything "odd". i heard what i thought was a slight squeaking noise or metal on metal noise, that i did not remember hearing before, so i got worried and decided to drive it a while hoping to dry out the manifold before anything bad happens. when i came home about 5-10 minutes later, there were no leaks and no noise. I just want to know if there is anything else i should be checking to make sure nothing bad happens now?
