So I was able to install the TurboXS racepipe last evening in about an hour. I did run into a problem with one of the threaded bolts that hold the factory cat in at the back. The nut simply broke loose before the rod started turning so I was left with that piece sticking through the exhaust flanges. I had to unhook a couple additional hangers, move the rest of the exhaust out of the way, and waste 15 minutes trying to remove the rod once removed (its still in factory cat flange until I find my vice-grips DAMMIT).... but it was OK. The piece is wonderfully made and I really enjoy the flex-pipe welded in. THIS IS THE TRUE SIGN OF GOOD ENGINEERING. My hat is off to you TurboXS, I am impressed. :goodjob: I worked with two ramps that I backed onto, a jack on the drivers side front, a good tool kit, and my incredible good looks... which, of course, had the most effect on the whole process. 8)
After about 20 miles of driving, I get a nice warm tone from the pipe :jimmyt:... especially at low RPM's. It was 90 here in Phoenix today, so I am sure the "butt-dyno" :csweeney: I did is fairly invalid... but the turbo did begin to spool earlier, and I get the same high-pitched whistle as "Mr. Video", as I like to call him, did. Sounds good, looks good, and it will match perfectly with my CBE that should be here in a couple weeks.
The minor injuried were to my forearms... that cat was damn HOT :doh:... but it only burned me when my arm sat against it for about a minute.
PS... make sure you all remove the fiberglass adaptor ring that is around the front flange before you attempt to install the pipe. It comes off with a regular screwdriver prying the bottom edge and some needle-nosed pliers pulling from the top.
