1 - 3 of 3 Posts
Hi friends, I have a 2010 Mazda 3 2.5L and noticed my engine coolant will climb while idling or at low speeds. I have never had the engine temp lamp kick on, but I've seen the coolant temperature hit 220F in Torque. I also live in an extremely hot area during summer (average day is about 105F with spouts up to 115F). Should there be cause for concern here when I see the coolant temp climbing from 180F while idling or at low speed? I'm not much of a car guy, and I don't really know what temperature my concern should be warranted. Thanks for the help.
While idling with a fully warmed up engine, the cooling fan will cycle on and off. At what temps does the fan kick on, and back off again?
In addition to what m3iguy states above. Make sure fan clicks on when engine warms up as it should. you can use a scanner to monitor temperature and see when it clicks on and off. Guessing car has about a 195 F thermostat, so fan maybe comes on at 205 or 210 F, so 220 F maybe not unrealistic. Also, note gauge temp may not be super accurate, use scanner to monitor.
1 - 3 of 3 Posts
