I have about 6 hours of good listening and tweaking on my new sub, and I have a few observations. I start at the beginning when my sub was first installed.
My sub is a 12" aluminum cone, 14-inch xmax 4-ohm single-coil woofer optimized for really low distortion, sold by Parts Express. It is leftover from a home audio system, so I figured I may as well use it as it is a very good driver. The x-max is about 2/3rds to half what a high-end car audio driver of this size would have, though it is considerably better than the cheap ones.
I built the (sealed) enclosure out of MDF myself. It has 4 internal bracing ribs as well, all screwed and glued together. The sub is powered by a 300+ RMS Profile Baja amp, with high level inputs. The amp was installed by CarToys, with the EXPRESS instruction to DISCONNECT the rear speakers and route them to the amp.
When I first connected the sub, I deliberately kept all of the gain low for safety's sake. It didn't seem to matter at first, because the modest output I was getting at first seemed like a revelation to me compared to the system without the sub so I only turned it up a little bit. I also (mistakenly) thought the SUB sounded rather strange in the midbass as I turned it further up, so I kept on turning the gain back down when this distorted sound intefered with my music enjoyment.
This morning I discovered that the strange sound in the midbass was NOT the sub. It was the friggin' rear door speakers. Car Toys left them connected!!! Until I have time tomorrow to tear apart the dash and clip the wires to the rear doors, I turned the gain up considerably at the amp, so I can almost fade out the rear doors, but still get a several times greater bass volume than what I was getting before without being able to hear the rear speakers.
Now if the first install of system was a revelation, the bass boost from the subwoofer with out the horrid "fill" behind me from the rear doors was even more so. Nothing less than a mind-blowing epiphany. I had no problem turning the sub up even more, since I was no longer getting the horrible cancelations and confusing sounds from the rear doors.
Geesh Nina Hagen sounded great. So did Green Day's American Idiot album, Steve Earle, Lucinda Williams, Goldfrapp, and so much more. (I have been stuck in traffic for a total of six to eight hours in the last week, btw. All of this for a trip that in good traffic that should take 15 minutes each for a total of 45 minutes).
So I have independently verified something that I have been harping about for some time. You don't need no freakin' rear speakers. The system sounds better without the rears. Period. It is just plain a waste of good money. Even if the rears had been something better than the OEM speakers, they can only produce a sound that cancels out what you should be properly hearing only from the fronts.
Using rear speakers for fill makes no sense from a theoretical point of view, and my ears have independently confirmed this in a completely accidental blind test. I bet none of those insisting on rear fill have actually done a blind test. I now have.
