OK, I posted a while back with a cold weather starting problem; the car would start and then die. After 2-3 starts, it would remain running, but for the first 2-3 minutes the engine would miss under acceleration. It continued through several tanks of gas, so I quickly ruled out fuel contamination.
I took it to the dealer for an inspection. They checked plugs, plug wires, ignition coils, fuel pressure, and the IMRC. None of that turned out to be the culprit. Anyone else experience this, or have any other good ideas? Here is what Mazda came up with: use 87 octane. Their theory is that the higher octane fuel isn’t being burned well enough due to the combination of altitude and temperature, and that a more volatile fuel might burn better. FYI, in the mountains 87 octane is mid-grade; the cheap stuff here is 85 octane.
Even if it works (and it’s too early to tell), I believe something is wrong. We’ve got a great fuel injection setup and the compression ratio is reasonably high, so something else must be going on… I should be able to start the car at 30 degrees F at 5,300 feet elevation with no problems.
