1 - 3 of 3 Posts
Selling an Alpine MRP F250 speaker amplifier. It runs great,never misused. Has 3 small chips/scratches on it and it is missing 1 terminal screw(dont know where it is but you can get another at an audio place). Also, this is NOT a refurbished amp, Ive owned this for 3 years now straight out of the box. Online, reburbed ones go for around $125, I'm only looking to get $110. Here's more details on it:
# 4-channel car amplifier
# 40 watts RMS x 4 at 4 ohms (50 watts RMS x 4 at 2 ohms)
# 100 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
# 2-, 3-, or 4-channel output
# variable high-pass/low-pass filters (50-400 Hz, 12 dB/octave)
# tuned Bass EQ (12 dB bass boost at 50 Hz for channels 3 & 4)
# subsonic filter (15 Hz, channels 3 & 4 only)
# MOSFET power supply
# CEA-2006 compliant
# STAR Topology (minimizes internal noise and prevents ground interference)
# speaker- and preamp-level inputs
# preamp outputs
# gold-plated screw terminals
# fuse rating: 15A x 2
# 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
# 11-1/4"W x 2-3/8"H x 9-9/16"D
Aside from the amp i also am selling my other sub woofer box. It was built and carpeted at a professional shop. It supports 2 12" round sub woofers and has 2 velcro strips on the bottom to prevent movement in the car, i can take that off if you wish.Looking to get $70 Here are the measurements, tho they are not exact,but close:
Length: 31"
Height: 13.25"
Botttom Depth: 16.75"
Top Depth: 14"
More Pictures available on request.
1 - 3 of 3 Posts
