1 - 20 of 27 Posts
Bought a new '09 ms3 2 weeks ago. Is putting a new intake really worthwhile?
Will I really notice an improvement in performance??
Thanks
You might notice a difference, one thing to keep in mind that is in general opening up the breathing of your engine will also help you achieve better gas milage, so long as the intake was well designed and you aren't flooring it 24/7.
He has a speed3 and will definitely notice a difference. Most people on here report ~20hp gains with intakes on speeds.
Yes. The reason the stock intake is so restrictive is because it was designed to reduce a lot of noises. However most people think it's a good thing to be able to hear the bypass valve working and turbo spooling :)
make sure you get an intake with the proper maf size and a maf straightener or you could run into problems with cel's and fuel trims being off. believe it or not, the mazdaspeed intake is crap and can trigger a cel.
only cobb and cp-e have the specs correct and i have to recommend cp-e's intakes over cobb's simply because the build quality is much higher (cobb's maf straightener is plastic, cpes is metal, etc.) and cpe makes everything in house.
the intake is the best bang for buck power mod and usually the first mod for most people, highly worth it and very easy to install yourself.
i have the Mazdaspeed intake with the AEM airflow straightener and love it :p. ive never had any problems even before i put the straightener in.... :yay:
[quote author=sleeperstang1994 link=topic=139553.msg3009638#msg3009638 date=1237732406]
Before I chose the ms3, I was also considering a wrx. I could be wrong but I think Mazda service said Mazda has their own improved intake and will available shortly.
In terms of noise, if a turbo back/cat back exhaust is a 10 at how much louder it makes a stock car, how much louder will a less restrictive intake make?
what do your st/lt fuel trims look like? do u have a monitoring device to show me some logs, how about knock? unfortunately, the aem designed cai was recalled once already, they fixed the air straightener issue, yet it still has a larger maf tube than stock. trust me, its not the best intake.
to the op, just youtube some videos of an intake on an ms3. its not rocket science that it will make a suction noise and be noticeably louder plus give you more power.
[quote author=mazdaj link=topic=139553.msg3009240#msg3009240 date=1237689814]
believe it or not, the mazdaspeed intake is crap and can trigger a cel.[/quote]
Welcome to last year. Please don't pass out bad information and personal opinion as fact.
Which would produce more hp gains, Cobb intake or Cobb Accessport?
Anyone hear that Mazda has a less restrictive intake available as an aftermarket?
Also, I understand the 2010 ms3 will have wider tires (225 vs current 205). Can these wider tires fit on a '09 stock wheels?
I would get an intake AND a turbo inlet pipe (both CP-e and COBB make both). The inlet pipe goes between the intake and turbo, completing the intake, so dont just get half of it! Corksport also sells their intake + inlet as one item for very cheap!! As for sound, it doesnt increase exhaust too much i think, but you can hear the turbo spool and bypass air being blown back into the intake, it sounds amazing!!
There should be plent of videos on youtube of MS3's with intakes. It is loud, but it's a good loud, and can't really be compared to the sounds of an aftermarket exhaust system.
[quote author=watchurwrist link=topic=139553.msg3009780#msg3009780 date=1237739754]Anyone hear that Mazda has a less restrictive intake available as an aftermarket?[/quote]
Sorry but based on this question alone you really need to do some searching before throwing out questions answered hundreds of times already. Including previously in this very thread.
:mz3corkey:
[quote author=spnkr21 link=topic=139553.msg3011084#msg3011084 date=1237802667]
Fuckin newbs. An air intake isn't going to get u 20 horse and u won't notice any gains. Use the search button next time u have a stupid question.
wow! it seems it only takes about 22 post for you to become a SR. member and start trashing "noobs"
Dude I noticed instant difference when I dropped in a K&N. Then 1 month later I cut out 2 larger wholes on the stock box and put an aluminum screen to keep out big debris and it pulled and sounded better than before. I put on a CAI, no difference. Now I have a short ram home made, due to L2AIC room and I don't notice it any better than the cut stock box. Oh it is LOUDER but not faster now.
Fuckin newbs. An air intake isn't going to get u 20 horse and u won't notice any gains.[/quote]
You have absolutely no idea what you're talking about.
[quote author=Ryz link=topic=139553.msg3011174#msg3011174 date=1237811385]
+1. Were talking about a speed3 here idiot, not a normal 3. The speed3s do, in fact, gain 20hp from an intake and there are plenty of dynos to prove it. GTFO.
A 3 inch tbe will gain around 20 horse. An intake will not. I know that we are talking about a speed 3 I have one. I now remember why I never come to this site because they're always the same questions; "which intake should I get? Which BOV should I get? Will I get 75 horse if I paint my emblems?". Love you guys :p
+20hp to that response
Yeah, I got the original Mazdaspeed intake and not one single issue and hell yeah I got more HP as measured by the butt dyno. Gas mileage got better also as noticed on a 240 mile drive that I had done before and after. The drive was not done to test, just something I always did to see what kind of mileage I was getting. There is more noise but I like hearing more growl, the spooling and release too.
1 - 20 of 27 Posts
