I installed a Borla Catback exhaust (with the reasonator) and its the perfect sound. passes inspection and its not to loud and not to quite. a nice backfiring noise when downshifting.
BORLA!!!!!
BORLA!!!!!
You don't want the MSDS with anything less than the 2.5L, nothing else makes enough torque to make that header worth it.It seems awfully hard to find a video of anyone with a Racing Beat exhaust and an MSDS header, either with a 2nd cat or a test pipe. I want to run this setup, combined with a good tune, for my power stage 1. I like the smaller diameter of the RB cat-back system compared to my runner up, the Borla @ 2.5"; I think that size will pair better for a 2.0L engine mated to an auto tranny. It's also the 4 speed, don't forget. I have fewer choices for picking the right gear, so I can't afford to trade too much midrange.
Anyone near DFW, Texas with this combo? Any links to vids even?
Comments on this combo? I don't have any other power mods yet, other than free stuff like TB coolant bypass & timing advance.
What is the difference in primary tube diameter between the two? I like the MSDS collector a whole lot more.You don't want the MSDS with anything less than the 2.5L, nothing else makes enough torque to make that header worth it.
Get the vibrant.
There's a video on youtube of my car.
I understand what you are referring too; however, I feel like there a couple reasons why I don't believe you.4-1 vs 4-2-1
It's completely different.
Unless of course, you plan on keeping your car around 6,000 RPM everywhere you go.
you'll have no torque. Especially out of a 2.0L
XCNuse answered this question literally 4 posts above yours. :lol:hi there from canada...looking for a good header for my 2005 3
thx rick
It will be louder and possibly set off the check engine light depending on the year. Not to mention it's against federal law. You will gain power and possibly fuel economy though.Does anyone here have any input on running a stock mazda3 with ONLY a race pipe installed? Would there be any cons to this?
I do emissions inspections in NY and yes we need to visually see the cat. Also, the 2nd cat is monitored in the CA emissions version of the 3 for that year AND if you do have a CA emissions vehicle in NY its illegal to install a non-CA certified cat and the cat has to be CA-certified specifically for said car. If its a non-CA car then you can pretty much put any cat you want.I have 2 catalytic converters on my car, since the rear cat is not monitored and the cs power series exhaust deletes the rear cat, and would not show a cel, would i pass emissions in ny? They visually have to see a catalytic converter, should i buy the high flow cat or not?
Doesn't matter. Multiple states require new vehicles to have CA emissions systems, almost all in the northeast in fact. Check the emissions sticker under the hood, if it says anywhere that it meets CA emissions then you can't legally use that exhaust in NY unless you have a shop modify it to fit with the stock cat in place.When i bought the car last month the carfax stated it was originally from another state but not ca,
I dont mean to sou d stupid or anything, but i just want to make sure i have the correct information before spending my money. Did research on the emission labels im going to check today but if it says it meets ca and epa standards i wont be able to change out the cat and take the exhaust to the shop, but if it says it meets federal standards, and doesnt mention ca, i would be able to get away with a high flow cat? Or would i still have to modify the exhaust?Doesn't matter. Multiple states require new vehicles to have CA emissions systems, almost all in the northeast in fact. Check the emissions sticker under the hood, if it says anywhere that it meets CA emissions then you can't legally use that exhaust in NY unless you have a shop modify it to fit with the stock cat in place.
This is correct. Borla, Magnaflow, and Racing Beat systems use the stock cay so yes they are legal.I dont mean to sou d stupid or anything, but i just want to make sure i have the correct information before spending my money. Did research on the emission labels im going to check today but if it says it meets ca and epa standards i wont be able to change out the cat and take the exhaust to the shop, but if it says it meets federal standards, and doesnt mention ca, i would be able to get away with a high flow cat? Or would i still have to modify the exhaust?
Edit: borla states they are legal in all 50 states would i need to worry about anything in terms of legality?
