1 - 19 of 19 Posts
Well I'm looking for some braking improvement and when I was a super noob, looked at big brake kits and wished. From reading for the last few months I've learned there are better and much cheaper ways to make you have stronger brakes. I've heard around new brake lines make a big difference, does it? Is it a good buy?
http://www.streetunit.com/Techna_Fit_Brake_Lines_Mazda_3_p/ma-1300.htm theres the ones I'd prob get.
They won't make much of a difference in daily driving, but when using the brakes aggressively and repeatedly (e.g. on a track) they will help prevent that squishy pedal feeling since they won't expand when heated up a lot. I would recommend putting in some good fluid (i.e. Motul RBF600) at the same time as the new lines for the best effect.
[quote author=cali_axela link=topic=134708.msg2896475#msg2896475 date=1233174850]
Ah I see, perhaps I'll wait then, cuz I haven't taken my mazda on a track yet even.
+1 they'll give a firmer pedal feel but you wont notice it much unless you're braking hard alot. try upgrading to slotted rotors and new pads first (i suggest hawk hps or ebc's)
[quote author=Verto link=topic=134708.msg2896540#msg2896540 date=1233176748]
Yeah when it was time for new pads I was gonna go with Hawks.
slotted rotors are a waste of money, better pads are NOT a waste of money
how a slotted rotors a waste? they vent the pad gasses and prevent the pads from floating when you brake hard...
Well if he isn't even going on the track yet, I would say slotted rotors are a waste. Get some pads first and enjoy. Slotted rotors, IF you really need them for track, won't be needed for some time... you will know a lot more by then and know what to get and what to do to your car.
[quote author=Verto link=topic=134708.msg2896585#msg2896585 date=1233178133]
New pads no longer turn into gasses
organic ones still gas a bit when braking hard, material burns off. like ebc greens.
pads dont really gas anymore as the organic material is nearly none existent in new pad compounds. while they can produce gases this only really happens at very high temps. slotted and/or drilled rotors will give you very very very little performance for the money you are spending on them. get a good set of pads and do a full system flush with some castrol syntec DOT4 brake fluid and you will be happy as a clam.
Discussion Starter · #15 ·
So perhaps the SS lines are worth it, even if I'm a street driver?
i say yes...
ultimately, you do things to your car for your liking, not what others tell you. People throw in bigger turbos and shit on their car and street their car and never hit the track. its all what you want.
Discussion Starter · #18 ·
I want a turbo! :p :lol:
[quote author=Freddyboi link=topic=134708.msg2904836#msg2904836 date=1233523192]
i say yes...
true, but you can notice a turbo on the street.
From behind the wheel, I GUARANTEE you that you will never notice any difference with slotted rotors versus solid rotors unless you take your car on a TRACK (you won't even notice anything different at autocross, it'd have to be continuous lapping w/ repeated stops from almost triple digits).
1 - 19 of 19 Posts
