1 - 12 of 12 Posts
Ive searched the forums and didn't see exactly what I'm looking for. I've got a 2011 mazda3 i sport sedan and I want to add the fog lights. I found this kit on eBay which includes a new light switch. http://m.ebay.com/itm/290739243749?nav=SEARCH
Is this a relatively easy install? From what I've read the wiring harness should be there and these lights will bolt on and plug in. Is this correct?
The wiring should be present in your car regardless of the model. It should be a plug and play application. However if the part is not genuine oem you may need to do some rigging of some sort to get the desired results.
I ordered the oem parts off of eBay. I'm guessing there's no other way to install the fog lights than removing the front bumper or can you get them on from underneath?
To install them you will need to remove the bumper. They Screw on to certain holes that were predrilled at the factory.
its best/easiest to take the bumper off. you could theoretically do it by removing the bottom splash shields and reaching in, but that would be pretty difficult.
The kit/part you ordered is the lights, housing, and wiring. you still need the switch (not included in what you ordered), unless you already have it.
the p/n for the switch is BBM3-66-122
its $45-65 - http://www.ebay.com/itm/NEW-OEM-FRONT-FOG-LIGHTS-COMBINATION-SWITCH-2010-2013-MAZDA-3-2012-2013-MAZDA-5-/360924243806
its pretty easy- plug and play into the steering column.
Assuming the 2nd gen is the same as the first gen there are a few ways to do aftermarket add on fogs. If you use the factory wiring then you could connect the new fogs to the existing wiring in the bumper. You'd probably need to cut the connectors as I doubt the aftermarket housings would mate with the OEM plugs. Then you'd need to install the OEM turn signal stalk with the included fog light switch. That's it.
If you're installing an aftermarket switch then likely the kit will want you to independently wire the fog lights for power. Not really a big deal as you'd just need to tap power (battery), a signal wire, a ground, and the switch. I'm imagining this is one of those rectangular switches which goes next to the steering wheel in the blanks on the dash?
Discussion Starter #9
How do i get access to the steering column to remove the old one and install the new one? I saw two screws on the bottom and I removed those which loosened it up a little, but not much. What else needs to be done to get it off without breaking it?
Remove those two screws you found. Extend and lower the wheel as much as you can. Grab the rubber cover on the top and work your way around it popping it loose from the top plastic part. That part should come off then.
There are a few screws holding the stalk into the column (I think, it's been a while). Unplug the harness from the base of the stalk, then pull the bottom section down just far enough to slide the base of the stalk out of the column.
Reinstall in reverse.
hate to hijack he thread but can sumone link me the switch for a 2013 mazda 3 with autmoatic lights...cant find it any where and they want slode to 200 for just the switch at my local dealer...or maybe if sumone can link me the full kit for a 2013 would be great!
Sedan I hope?
Switch
CD83-66-122 SWITCH, F $59.75 plus shipping 1-2 days to get
Fog light kit with out switch
BGV4-V4-600 FOG LIGHT $218.82 In stock
Chris
1 - 12 of 12 Posts
