I have one amp already hooked up for my sub it uses 4 gauge power wire from the battery and 4 gauge ground it is rated at 600 watts i believe.
I just bought a new amp for my door speakers. What will i need to just add the existing amp to the setup. I was thinking i could just get...
Distribution block , power wire ground wire, and speaker wire
Can I just put the distrubution block on the existing power line from the battery, split the power wire to the 2 differents amps. Then just ground the other amp and run the other wires to the head unit.
Will this be all i need?
Kicker Hyper-Flex 12 AWG Speaker Wire
12 Gauge S Series Hyper-Flex • Twister Pair Conductors • 20 ft. Spool
Lightning Audio Strike LSSDCRT4 Wire Terminal
Strike Series Platinum-Plated 4 Gauge Ring Terminal • Dual Outputs
Stinger Custom Pro SCPRO4B Power Wire
Custom Pro Translucent Brown 4 Gauge • 1666 Strands
Stinger Custom Pro SCPRO4R Power Wire
Custom Pro Translucent Red 4 Gauge • 1666 Strands
Stinger HPM Series Distribution Block
Platinum-Plated 4 Gauge • "T" Style
