If you're ever tempted to drive your car around to test something you're working on, with the lower plastic underbody covers off... DON'T DO IT! I just tore the shit outta my wheel wells, all the plastic is all mangled up into pieces, scratched my bumper (not anywhere really visible, but still) and may have damaged my air filter element.
What happened was: I hit a small bump while in a turn, and I guess there was enough play in the wheel well plastic piece since it wasn't secured in place by being connected to that lower cover like it usually is. There's normally less than an inch of space between the rx-8 wheel and that plastic anyways, and just getting stuck there for a second was enough to be catastrophic. Worst noise ever... locked up the wheel, had to pull over on a relatively busy street and spend 20 minutes turning the wheel back and forth and ripping pieces of plastic out from between the tire and the wheel well so that I could drive the rest of the way home.
All this happened in about a 10 block radius of my house after installing a new turbo return line and just wanting to test for leaks. Wasn't even driving crazy. So be warned... that plastic down there holds the wheel well plastic in place, so don't drive with it flapping loose, even for a few blocks, if you're lowered and have aggressive wheels.
