1 - 8 of 8 Posts
2007 Mazda 3 2.0L. Manual Trans.
Hello all,
Last year I was working on figuring out why my A/C would work for about 10 minutes and then die out. I changed the cabin air filter, to no avail. I checked the A/C relay, no difference when swapping with Horn relay.
https://www.mazda3forums.com/57-mazda3-axela/761730-c-mazda-3-a.html
Now that it is warmer again after winter here where I live. I am deciding to take a look at this issue again, but now the A/C is not working at all. The A/C clutch is not engaging. I didn't have my manifold set to see the pressures from Low/High, but I did use a low side gauge that comes with refrigerant. It was in the Red area really high pressure. I assume that is because the compressor/clutch is not turning on. However, my light in the car is on for the A/C no blinks just solid green. The clutch moves when I turn it so it is not seized.
What can I test before I considering replacing the A/C compressor?
Thanks!
Discussion Starter #4
Did you check to see if power is coming into the compressor?
I did today, test the connection that the compressor connects to, coming from somewhere above. I did get voltage when A/C button was on and when turned off nothing. So I assume there is power coming in. I tested resistance on the connection to the a/c clutch coil. On the multimeter I used I got a result of 1 Hmm...
Is the ac light on the climate control unit coming on (green)? I have had two m3 and both had issues with the climate control unit AC on/off button.
Don't forget to check the easiest thing first: the A/C relay. It's the same as the horn relay, and right near it in the underhood fuse box. Just swap them with one another, see if that fixes your problem.
did you get this fixed? it may actually be the clutch. its easy enough to change through the passenger side wheel well
I can't believe someone thought replacing the cabin filter would fix an issue with the A/C not running.
1 - 8 of 8 Posts
