That in most cases is either the amp or the speaker. The easier to test for you (DIY) is swap the left to the right speaker temporarily and see if the noise goes away.
Thanks, I should've included that I have used the tuner to try and locate which speaker was buzzing. On the tuner controls you can hear buzzing in every position except for full left and full right, which I believe are door speakers. The buzzing is more pronounced the farther right you adjust the tuner. Looking in the trunk there is a single large speaker and three of these smaller ones. Two smaller ones on the right side and one on the left. Just by pressing your ear up to them you can hear that it is the smaller of the two right speakers.That in most cases is either the amp or the speaker. The easier to test for you (DIY) is swap the left to the right speaker temporarily and see if the noise goes away.
Read the complete thread up to this point again. Suggestions have been posted on how to determine fault.I have a 2022 Mazda3 2.5 Turbo ....... The right rear speaker is buzzing
Yes the warranty covered the repair but the idea that a brand new car needed $4400 of work is unforgivable. They told me a “faulty factory part” was the culprit. It still RATTLES. I’ve seen on here that a lot of Mazda owners have rattling issues with their vehicles, even newer ones. I’m still under 10k miles and still woefully regret this purchase. The service from the dealer is equally unacceptable. When the large repairs were made, I had to take the car back because they left a splash guard barely hanging on, as well as failing to put other pins and small pieces back on the car. I mean, stop me when any of this makes sense!Apologies to the OP for following up on this post. But "2022 Mazda3 2.5 Turbo with just over 7000 miles"? Warranty? "I’m thinking there is always going to be something with this car." Really? And you paid how much for this car? Rhetorical. Mine went back (3 times) for a cruise control issue that many people would not even have noticed until they finally fixed it. They will fix yours too. But they won't know the problem exists unless you bring the car to them.
STOP!I mean, stop me
Please for the love of Pete just sell your car and move on to something else that you like better. Your repetitive harping on the same issue in multiple threads is beyond tiresome. Sure your car has had issues and you are justified in being upset about it, but you are beating this into the ground.Yes the warranty covered the repair but the idea that a brand new car needed $4400 of work is unforgivable. They told me a “faulty factory part” was the culprit. It still RATTLES. I’ve seen on here that a lot of Mazda owners have rattling issues with their vehicles, even newer ones. I’m still under 10k miles and still woefully regret this purchase. The service from the dealer is equally unacceptable. When the large repairs were made, I had to take the car back because they left a splash guard barely hanging on, as well as failing to put other pins and small pieces back on the car. I mean, stop me when any of this makes sense!
