Just read up on them, they are typically applied with a dab of high heat RTV. Looking at the OP picture closely it looks like RTV is used there. I personally would probably remove it and if worried reapply it elsewhere where it won't interfere with any mechanical components.Heat Tabs are very common when buying an engine from a salvage yard. That way if you have a claim, they know it was actually their engine. I think they're soldered on? Maybe brazed? Not quite sure how they're applied to tell you the truth.
Problem is you have to use the Mazda crankshaft pulley so you still need diamond washers. Mazda recommends replacing them with new ones and I agree. They are inexpensive and why risk engine failure over such a small part? At least this would be my assumption, but does anybody have other information?No pictures yet, but did find a few differences with this 2018 2.5 over the 2015 I used for the other 5:
The temp sensor in the head is not a blind hole like the 2015, it's in the water jacket so I will need to plug the hole. I'll just knock the top of the sensor off so it'll fit under the valve cover.
Remembered that I need a new crank bolt. In the 2015 Fusion service manual it said that the diamond washers can be reused if in good condition. I just looked up the 2018 Fusion manual: View attachment 107347
Not trying to be cheap. According to the Ford parts website, engines built after 4/2016 have the updated crank gear and do not use the washer. The gear is laser etched to provide the function of the diamond washer. They do not say anything about replacing the crank pulley along with replacing the crank gear so the crank pulley that originally had a diamond washer should be just fine using the laser etched crank gear.Problem is you have to use the Mazda crankshaft pulley so you still need diamond washers. Mazda recommends replacing them with new ones and I agree. They are inexpensive and why risk engine failure over such a small part? At least this would be my assumption, but does anybody have other information?
