First i want to say Hello as I am a new member on this forum...
I tried searching through posts for the last 2 hours and can't seem to find anyone with a similar issue...
I'll try to be as detailed as possible...
The car is a 2014 Mazda 3 2.0l manual transmission.
The problem I am having is constant but appears at random times but all within 2 hours. The only thing that happened leading up to this problem is the battery died several weeks ago, boosted the car, drove around for approx. 45 mins. Drove the car everyday for 4 days and later got stuck in snow from the plow blocking the car in, wheels spun a bit and was able to drive away...next day while driving the car the traction control and check engine light came on at the same time and I could not accelerate (no throttle response). Turned the car off, then back on...both lights remained on but I was able to accelerate...drove the car for maybe 2 mins and then no throttle...
Scanned the car and got several codes:
Scanned car again with a better scanner (Autel) and got several codes in the PCM section and 2 codes in the ABS section.
PCM Controller
I will just add that the car idles fine, and EVERY time I restart the car I am able to accelerate for a random amount of time before it cuts off the throttle.
Has anyone experienced this before? Any clue what it can be...I was thinking originally the Throttle body but why would I have throttle sometimes and then sometimes not...if it was the TPS shouldn't it either just work or not work?
Anyway I'm at a loss and I hope someone actually read though all of this and can help me out.
Thanks!
- P0102 MAF Low Input
- P0453 EVAP High Input
- P061B ECM Torque Calculation
- P2110 Throttle Actuator Control - Forced limited RPM
- P2122 Throttle Position or Accelerator Pedal Position sensor Switch D - Low Input
PCM Controller
- P0102 MAF
- P0453 EVAP
- P061B ECM
- P151B Idle Speed Control - RPM lower than expected
- U0401:00 Invalid Data Received from ECM/PCM
- U0401:00-2B Invalid Data Received from ECM/PCM
Thanks!
