I’m getting a dash vibration from either the middle of the dash or from the passenger side. It vibrates when I accelerate. Does anyone know how to fix this or where it may be coming from?
DoesMine (2011 model) does this at about 2,700 rpms in cold weather. My dash top has previously been replaced in a recall. I too am curious if anybody has found a source for this.
Did the recall fix the issue?Does
The vibration your speaking of I believe is like mine, in drive foot on break once release brake it goes away. Vibration is more of a rough idle, well mine was, there is a vacuum leak at the back of the brake booster( big metal disk shaped thing on driver side or on the pcv valve between black intake manifold and the engine block. Fix >> replace hose &/or the plastic connector on brake booster. In the case of pcv valve replace valve (most likely have to remove intake manifold to access) I just replace both while I was at it. Youll notice a huge increase in fuel economy back to where it normally should be.Never heard of a dash vibration on the 2010-11 3 until now - If you find out the issue please share ! I remember issues with the 2010-11 dash but it was related to the dash literally melting on hot days - It was made of some synthetic material which was designed to be soft enough to allow the passengar side air-bag to easily tear it open - I can see a faint X over the glove box where its located - Did the vibration just start or was it always like that ? Is it a sedan or a hatchback ? - The sedan came with a 2.0 or a 2.5 - Whats the mileage ? Did you ever have an accident ?-Is it a manual or automatic transmission ?
I get a slight vibration in my 2.5 HB / but I think its pretty common that it does so when idiling at a stop with my foot on the brake - automatic trans - but it never kills and goes away right after I lift off the brake -
