1 - 12 of 12 Posts
Need to replace one rear wheel hub/bearing on my 2010 3 -2.5 gt - There are 4 bolts which thread from the inside out and affix the new hub to the suspension -thru the dust plate - it appears the torque spec on these 4 bolts is 33-44 ft-lbs - which seems very low - anyone replaced these wheel bearings before ? - just looking for redundancy and accuracy - Many thanks fellow wrenchers - !
I've done the job a couple of times, it's easy. And 44 ft lbs is fine, just be sure to use blue threadlocker so they don't back out unexpectedly.
Thanks - I just ordered a service manual after 11 years of " winging it " or asking for spec help- Like from you ! which I do appreciate ...I have the orange permatex thredlocker for the calipers/ plugs ...but i suppose these may not ever get removed again - so blue it is -
Regards !
Regards !
Blue isn't the "permanent" one, red is! Blue you can break if you need to.
Thanks again ! - very much -confident with my abilities - yet get queasy on torque range accuracy here -
the blue permstex is on order thanks to you - After looking at the OE repair manual it shows those 4 bolts that thread inside to out which attach the bearing-hub now at
24-32 ft-lbs each? - which seems even more absurd - I mean - the entire weight of all the wheel : hub : vehicle / are supported by 4 bolts that are collectively about 100-120 ft/lbs - yes the caliper is on the trailing arm -but it still seems low -Wheel bolts are at 87ft/lbs each - - Two people said - ahh just get it tight - forget the torque wrench - but engineers do math and testing ? - thread lock must be the key -
When you did your bearings , did you just pull the caliper off the rotor and hang it with twist ties off to the corner ? I dont want to play with brake pads or parking brake cable and just want slide the caliper right back onto the rotor / -?
For anyone else forseeing your rear bearings/hub needing replacement( 2010 -3 2.5 rear ) / A distributor on Amazon has 4 OE new- speed sensor not included - but im reusing mine anyway -
BBM2-26-15XB is the MAZDA OE stock # for $139.00 / each !
Lowest ive seen - dealer retail around $200- most parts are going up now. Its even less than shop wholesale cost w/o tax !
Thanks again
The bolts aren't very big. M8's at the most. That's why they don't take a whole bunch of torque. A wheel stud is an M12. A bolt that size can take 100 ft. lbs. That little M8, (may even be a 6) will snap if you try to give it the beans like that.
Yeah, on the back, you have the e-brake cables that will suspend the caliper in the air without having to do anything special like hang one from the spring.
Check Rockauto for the bits. Lots of fake parts on Amazon and the 'bay....
Appreciate that - However , I have an OE bearing : hub from Mazda and the seller on Amazon confirmed its NEW - not reman , sealed , boxed Mazda OE from Japan /Cost $139.50 which is about $65 off retail and even less than wholesale shop cost with tax- It seemed to good to be true- but its arriving today and if its not spot on match , weight , packaging /the seller will refund %100 - So
Not sure how they got them as its rare to get these type of parts OE outside the dealer/ unless a dealer sold out , which happens / I worked at a few Mazda dealers and i should be able to spot if bogus- they have three left - i did one side / rear at 142,000miles and i noticed it immediatly and an doing both - If theres any car worth saving its any Mazda 3 2010 ,11/12 -2.5 (,except the manual trans models ) as that engine is a 300,000 mi beast - because they took parts from the turbo 2.3- forged bottom end , power coated connecting rods, 4340 moly piston sleves , graphite pistion skirts , stainless steel exh header, alum pistons , heads -The cat converter was engineered to last and uses far less platinum and is efficient -
every time i see a 2.5 listed in a salvage yard its stripped to the bone in one day - seldom get any good parts , gotta be quick - of you need rear bearings check out the amazon list - they had 3 left - ? - if bogus i will follow up -
Genuine Mazda BBM2-26-15XB Wheel Bearing and Hub/. NEW /OE 2010 2.5
Interesting in that you are getting an OEM part from Japan for $139.50 via Amazon. Not sure why people think Amazon is always a great deal. A 2 minute search gave me Mazdapartsonline.com, and they show the rear hub/bearing at $134.67. Guaranteed in Mazda box and guaranteed to be the real deal. Let us know how it works out.
Discussion Starter · #10 ·
Well. ~ the lowest price is one criteria. , and i have not previously purchased any parts from Amazon - regardless -
Well i just check'd mazdapartsonline.com and that exact bearing/ hub assembly from them is $156.16 plus shipping - so its over $22 more before shipping and Amazon is free shipping in this case . ...So Im pretty happy - yes - and I seldom buy parts online as I have access to dealer parts from a dealer which I prefer for ease of exchange and warranty -
mazdapartsonline.com price ....
Product Font Parallel Circle Screenshot
Discussion Starter · #12 ·
I received the hub/bearing today from Amazon and its identical to the one i purchased at the dealer , in the correct box,correct numerical id , however the box had been opened and re-taped closed - but even at the dealer the boxes are often open for inspection - It has machine etched number on the back of the flange - which my parts guy at the dealer said is typical of Ford parts , and I asked how these OE parts end up on Amazon - he said ....often dealers want to liquidate their parts inventory and use a dummy company name to sell thru Amazon so they dont ruin their full retail sales -Also remanufacturing these was more frequent but less now as theres not enough demand to make the price gap worthwhlie - If anyone has knowledge of these etcd numbers - please advise - They clearly show them on their ad -
Automotive tire Font Auto part Nickel Gas
1 - 12 of 12 Posts
