I have a 2009 Mazda 3 with 230,000+ miles on it. It is running great, but it does not take bumps in the road well. I ordered shock absorbers for the rear end months ago and finally got around to replacing the old ones.
A brief background about me. I'm an engineer and have tinkered on cars a bit over the years, but I am miles from being a good auto-mechanic. I figured changing the shock absorbers would not be a bit deal. I got that wrong!
I figured this would be an easy job. Just jack up the car, remove a few bolts, remove the old shock absorber, insert the new one, fasten the bolts and done! I watched two U-tube videos to get instructions.
Well, it took about 2 hours to remove the old shocks, not the 20 minutes I anticipated. I re-watched a section of one of the videos 2 or 3 times because I was having trouble removing the old shock absorber. One problem I had was my own fault because it took a while to realize the bottom bolt is to be removed from the inner side of the wheel, not the outer side. But the bigger problem was getting the bottom of the shock absorber out. It was VERY tight within the surrounding metal frame. After watching the video a 3rd time, I realize the bottom of the shock absorber was so tight that I had to apply some muscle to remove it. But I applied the muscle and out it came.
Now the BIG problem. How to get the bottom of the new shock absorber into the frame that the old one came out of. I tried twice with no luck. After 2 tries, I tried measuring the width of the bottom of the new shock absorber and compare it with the old one. As near as I can tell, they are identical (as expected). I don't have precision instruments to measure, but they certainly appear to be the same.
So question 1 - Is this typical of a Mazda 3? By this I mean, do all the rear shock absorbers on 2004 to 2009 Mazda 3's all have very tight fitting at the bottom of their containing frame?
Question 2: Has anyone else encountered this problem? (Note: maybe the frame where the bottom of the shock absorber is fastened is bent inward creating an abnormally tight fit and this is a unique case.)
I have been trying to pound the bottom into place with slight success. If I keep pounding, I maybe get the bottom into place. I will give it some effort, but my expectation if that I am going to bring the car to my mechanic and have him fix it. I did not see anything in the U-tube demos to indicate my problem is normal or to be expected.
Question 3: Does anyone have a suggestion on how to get the bottom of the shock absorber in place and secured? I know using a hammer and pounding it into place is not normal!
By the way, I am a glutton for punishment and I'm going to try to replace the other rear shock absorber. My guess is that the other side will go better, but time will tell.
Jim Anderson
Jim Anderson
