2009 Mazda 3,2.0l Wheel Alignment Help!!!!
659 Views 8 Replies 4 Participants Last post by  VWandDodge
2009 Mazda 3, sedan, 2.0l Standard no mods
Hello all, I have just changed my inner and outer tie rods and now doing the wheel alignment using the "String Method".
The drivers side is 1/8" = 1.6mm toed-in (within spec)
The passenger side is 3mm toed in which needs adjusting.
My question is; how many mm does the toe change (in or out) for ONE full turn of the tie rod?
I have checked this and it seems that a full turn of the tie rod changes toe by 2mm, does this sound right to you guys?
Thanks in advance
(y)
1 - 9 of 9 Posts
I don't really know the answer but wouldn't it be fast enough to just adjust it and measure it again?
Thanks for the reply, yeah, sounds like a reasonable thing to do but it actually took me a long time to adjust both sides as I was measuring, jacking up, taking the wheels off, adjusting, putting them back on, measuring again and repeating all that again!!!
So I was trying to find out if there's a shortcut, since then, I found a useful post on the net that said the following:
Measure the thread pitch of the tie rod (this can be measured or worked out from the hex size of the tie rod or the spec)
Say the pitch was 2mm, this would mean that the toe changes by 2mm for every turn of the tie rod.
I have yet to try that & will confirm when I do. If that is accurate, it would save so much time and effort and would align the wheels pretty tight I would imagine.(y)
Why not take it to an alignment shop as the rear also needs to be checked also for toe/camber and on a 2009 guaranteed the rear eccentric bolts are seized. Ask me how I learned this....
That would make sense but I'm trying to save a bit of money as I forked out $105 on an NTK O2 sensor just before I started doing the wheel alignment, am I right in saying that the rear accentric bolts are the bolts that adjust the toe on the rear wheels?
yeah, rear eccentrics adjust toe to the best of my knowledge. Just replaced them on my daughters car, a Sawzal with good blades was needed.
Ok, just a followup on the wheel alignment measurements issue, I tried the pitch measurement as mentioned before & the alignment is now pretty accurate. ✅ ✅ ✅ ✅
It's still advisable to get a proper 4-wheel alignment because you'll probably subject the tires to uneven wear.
1 - 9 of 9 Posts
